Reply
Circle erased my Profiles OrbiB108
ntheaux
Initiate
I think i'm going to be sick.  I went into the orbi app and discovered that everything i had setup is now gone?  No one is listed, devises are all listed under the house.  Is there a way to fix this without starting all over.  I did look at the manage button and swear i had a backup b/c i changed phones and had to recover that.  I hope there is an easy fix.
On a totally different subject i had to call netgear soon after buying it about an issue i was having and the guy (located in india) convinced me to buy the extended warranty for all devices in my home - but can't find that anywhere.  I know i got a confirmation for the service but can't find it.Any idea of what i can search in my email to find it?
TIA
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: Circle erased my Profiles OrbiB108
Please post about this in the Circle app forum:
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M XR1000 (Router Mode) RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @ntheaux, I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 874 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
