Reply
Highlighted
Circle keeps losing connection AC1900
I have seen this posted several times, but I cannot find a solution. I have had my router for about 6 months. It worked very well for 3-4 months. Then Circle stopped working. 5-6 times a day(and that's only when I am home), I get a notification that Circle lost connectivity. I have to constantly log in to reset Circle. This is so frustrating, especially when I am not home to reconnect!
Please help!! Thank you!
Message 1 of 8
Highlighted
NETGEAR Moderator
Re: Circle keeps losing connection AC1900
Hi @Orion17,
Welcome to the community!
1. Please check for the exact model number of your device.
2. What are the steps that you have tried so far?
Dexter
Community Team
Message 2 of 8
Highlighted
Sorry, I wrote the incorrect model number. The correct one is: R6900P
I was one the phone with tech support for over an hour before I lost connection with the service representative. He walked me through restarting the router twice, but it didn't seem to work.
Message 3 of 8
Highlighted
NETGEAR Moderator
Hi @Orion17,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 4 of 8
Highlighted
I'm having the same issue.
Please send me a message with the secret solution.
Message 5 of 8
Highlighted
Can you send me any help to try to resolve as well please?  It is incredibly frustrating to constantly lose the Circle connection.  If there is something I can try, please let me know.  Thanks for any help you can provide as you work through this issue.  I do appreciate anything you can do.  I have an RBR20 (Orbi wireless router)
Message 6 of 8
Highlighted
I have this same problem.  Circle will no longer connect.  When I updated the firmware on the R6900P last week Circle connected for about a day, but now it will not connect anymore.
Model: R6900P|Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
Message 7 of 8
Highlighted
NETGEAR Moderator
Hi @leejarman, if you haven't yet, please try resetting the router to factory settings after the firmware update. This may clear up some possible issues. Please keep us posted.
Dexter
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1345 views
  • 0 kudos
  • 5 in conversation
Announcements
