Orbi WiFi 7 RBE973
Reply
Circle netgear has stopped blocking the YouTube
Ravipati
Hi Team,
I am not able to block youtube using Circle 1st Gen in my router R8000P. it used to work previously but now it is stopped work. Please let me any suggestions.
thanks & Regards,
Ravipati.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 7
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Circle netgear has stopped blocking the YouTube
Thanks for providing the info. We recommend leaving the IPv6 option off unless your ISP configuration requires you to do so.
Dexter
Message 4 of 7
All Replies
DexterJB
NETGEAR Moderator
Hi @Ravipati, we'd like to know the following:
What is the firmware version of the R8000P?
Are you encountering any error? If yes, please provide a screenshot if possible.
Does the issue persist when trying it on another device?
Dexter
Message 2 of 7
Ravipati
Hi @DexterJB
Firmware version is: V1.4.2.84_1.3.42
This problem occur only if I enable IPV6. Some of the sites are not blocked by 1st Circle if IPV6 enabled. When I disable IPV6, everything working find.
Thanks & Regards
Ravipati
Message 3 of 7
DexterJB
NETGEAR Moderator
Dexter
Message 4 of 7
Ravipati
Hi Dexter
Thank you very much for the reply. My ISP is looking for IPV6 enabled. otharwise I am getting IP confilts every now and then. Is there any chance to fix 1st Circle
-Ravipati450
Message 5 of 7
DexterJB
NETGEAR Moderator
Hi @Ravipati, please check your inbox.
Dexter
Message 6 of 7
Guru
Was this resolved?
@Ravipati wrote:
Hi Dexter
-Ravipati450
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2522 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
