smchais's avatar
smchais
Follower
Apr 15, 2021
Circle not working and in infinite loop to enable
Hi,
I’m unable to toggle parental controls on my Orbi app. The circle app is in the process of setting up, but it is in an infinite loop of enable Circle. I’ve already done a factory reset on my modem, deleted both the Orbi app and the circle app a couple times. I don’t know what else to do. I see where others only reset their router and everything worked properly afterwards. Also, now I can’t disable parental controls in the Orbi app. When I click that, it sends me to the Circle app, which is pretty much useless right now.
HELP!!!
Steven
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Steven,
    Are you still experiencing issues with the Circle app?
    Christian
      Christian_R
      Hello kimmiess,
      May you reinstall the Circle app and power cycle your router.
      Christian
