Jessiejade
Oct 11, 2023Aspirant
Circle parental control-son can easily get around this....need help!
The circle parental control box we have is connected to the orbi satellite which is connected to the netgear nighthawk modem. My teenage son has figured out that if he chooses the "netgear" wifi connection on his iPad and phone instead of the "orbi" wifi connection then he can get around the circle.
How can I block "netgear" as a wifi option on his devices?
Disable the wifi on the NG modem.
What model # of the modem and what Orbi system and satellite model do you have?- JessiejadeAspirantNet gear nighthawk AC1900 Wi-Fi
Orbi routers RBR20- FURRYe38Guru - Experienced User
There a C#### or R#### series model # for the nighthawk? AC1900 is a wifi speed.
