Orbi WiFi 7 RBE973
Reply
Circle passcode lost due to phone change
svikas
I have Family Cirle Enabled on my Netgear Router, but when I upgreaded my phone from a iPhone 7plus to a iPhone 10, I seemingly locked myself out.  The passcoded resend doesn't work and I don't know the 4 digit # ?
Model: ANT7000P-100NAS|2dBi Dual Band Omni-Directional Antennas
Message 1 of 5
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Circle passcode lost due to phone change
Hi @svikas, I have sent you a message. Please check your inbox.
Dexter
Message 2 of 5
All Replies
DexterJB
NETGEAR Moderator
Dexter
Message 2 of 5
Igtsvi
I am also experiencing the same issue. What is the solution?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 3 of 5
LlZoll
Having same issue. Cannot access anything anymore. This happened over night now my browser in my phone won’t even connect over WiFi and I’m not getting the admin text codes. Very frustrating
Message 4 of 5
svikas
They can retrieve the code for you. Please start a new thread as this is resolved. They will send you a private message and once verified , they can send you the code.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2667 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
