Discussion stats
  • 8 replies
  • 488 views
  • 0 kudos
  • 7 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Circle passcode not received on text
I am not getting the passcode via text on my phone to manage my existing circle on my netgear r8000 after switching phones despite selecting that I am the only admin.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 9
Highlighted
NETGEAR Moderator
Re: Circle passcode not received on text
Hi @Himanshunagpal, I have sent you a message. Please check your inbox.
Dexter
Message 2 of 9
Highlighted
I have the same problen I have a new mobile phone and I am not recieving the text to access the app I am the only admin. I let my subscription lapse thinking I could then reset everything this did not work please can someone contact me to reset my passcode once I can access the app I will restart my subscription. thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 3 of 9
Highlighted
NETGEAR Moderator
Hello AdrianNoble,
I will need the following info so that I can validate and retrieve the passcode from our system. Please send me the information in a private message.
Name:
Email:
Model Number:
Serial Number:
Thanks,
Christian
Message 4 of 9
Highlighted
I get the text but it says "Check the code and try again". Tried reinstalling the app, rebooting the router and turning off/on circle on the router.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 5 of 9
Highlighted
Same issue. Not receiving text sms messages
Message 6 of 9
Highlighted
I can not get my passcode either how did you do it?
Message 7 of 9
Highlighted
NETGEAR Moderator
Hello,
If you're experiencing issues with your Circle passcode, please check out the article below.
https://support.meetcircle.com/hc/en-us/articles/115001381172-Troubleshooting-common-issues-with-pas...
Christian
Message 8 of 9
Highlighted
None of that helps. As I said previously, I have been through those procedures. Can we try again with different advice please?
Thank you.
Message 9 of 9
