Orbi WiFi 7 RBE973
Reply
Circle passcode won't reset, no SMS delivered
chrisd0729
Follower
Circle passcode won't reset, no SMS delivered RBR50
I accidentially turned on Circle in parental controls and trying to disable it. I'm clicking "send me sms" and I never receive the text. How can I turn off Circle on my router? I try disabling through the Orbi app however, it won't let me disable through the app. When I try logging onto Orbi admin, I get a page saying "this device is paused".
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
dad_sri
Re: Circle passcode won't reset, no SMS delivered
I had set the bed time in-correctly and tried changing it to the rigjht time and it wouldn't work. I tried disabling Parental Controls & reenabling still no luck. Finally Deleted the app and when trying to manage the devide it is asking for a passcode. Since  old app was deleted asked for SMS text but is not working.
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 2 of 5
thonn
I am having the same probleam.  SMS text will not work. Can someone assist to get Circle back up again?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 3 of 5
Guru
Make contact with a forum moderator.
@Christian_R
Message 4 of 5
Christian_R
NETGEAR Employee Retired
Hello thonn,
I will need the following info so that I can validate and retrieve the passcode from our system. Please send me the requested info in a private message.
Name:
Email:
Model Number:
Serial Number:
Thanks,
Christian
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1443 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 7
