- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Circle seems to be randomly killing Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk X6 R8000
Firmware Version V1.0.4.62_10.1.74
Bitdefender installed
Since purchasing the Nighthawk X6 R8000 and activating Circle, I noticed and confirmed that Circle is randomly blocking access to the INTERNET. It does not distinguished between different access categories PARENT, TEEN or UNMANAGED everything is blocked.
Done already all Netgear support ask, Factory reset, manually uploading the same FW, seems a standard approach to calm customer down for a known and persistent issue.
Only by disabling Circle can I restore the Internet access of all devices.
Reading trough the comments about Circle the problem seems to persist for many years and I am wondering if Circle is worth the trouble. Like others I was hoping to control efficiently the internet access of my Teen, it works, but the other issues causing problem at home.
Does Netgear has a sure fix for Circle?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Circle seems to be randomly killing Internet
Hello klausiau,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
