Orbi WiFi 7 RBE973
Reply
Circle shows zero internet usage
cemtp
I have been running Circle app on Orbi for quite some time.
Recently it started to show no internet usage. I only see "No usage to report for this period".
I deleted the app and reinstalled but still the same. Any suggestions before I cancel the subscription?
Thanks.
Message 1 of 4
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Circle shows zero internet usage
Hi @cemtp,
Welcome to the community!
You can check the link below from Circle.
https://support.meetcircle.com/hc/en-us/articles/360002161692-My-Profile-Device-isn-t-Showing-Usage-...
Dexter
Community Team
Message 2 of 4
All Replies
DexterJB
NETGEAR Moderator
Hi @cemtp,
Dexter
Community Team
Message 2 of 4
DexterJB
NETGEAR Moderator
Hi @cemtp,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 4
cemtp
Thanks for following up.
Suggestions in the link didn't help so I cancelled my subscription.
Not an ideal solution but the problem is solved now 😞
Cem
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2969 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
