Reply
Circle stopped filtering
lok2236
Circle worked very fine for the first few months but from last 2 days I see it is not filtering at all..  None of the profiles/firewall seem to be enforcing,   it is allowing all sites / full access.      REinstalled the circle app ( i am using IOS version),  removed the unknown devices,   tried  creating a New profile, even with new profiles same issue..   But pause of a device or Profile stops the internet,
F/w version - 2.6.2.104
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Circle stopped filtering
Hello lok2236,
May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000062432/RBR20-Firmware-Version-2-6-1-36
Christian
Message 2 of 3
lok2236
Hi Christian,
Thanks for the suggestion..   Yes,  reverting to the old version mentioned helped..   Now the filtering is working as before..
For now I will keep the old version running, until the filtering issues is fixed in the new version of the ORBI f/w
Thanks
Lokesh
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
