Orbi WiFi 7 RBE973
Reply
Connectivity
jlcarpenter
Tutor
Connectivity
I am having trouble with the circle app when used with my Orbi router with built-in Circle. When I open the app it says cannot connect to circle. I try to reconnect with the same issue. I have restarted the app and the router with the same result.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Connectivity
Hi @jlcarpenter, welcome to the community! If you haven't checked yet, please make sure that the Orbi is set to router mode and not AP mode. The link below may help out.
https://kb.netgear.com/000058831/Why-can-t-my-Nighthawk-Orbi-App-detect-my-Nighthawk-Orbi-device
Also, you can try using another device (Andorid, iOS). Let us know how it goes.
Dexter
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Re: Connectivity
Dexter
Message 2 of 3
DexterJB
NETGEAR Moderator
Re: Connectivity
Hi @jlcarpenter, were you able to sort this out?
Dexter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1956 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
