orbi-customer
Jul 07, 2020Initiate
Disable Circle
Orbi worked great until we started using Circle. Wifi now stops at least once a week. I have to reboot everything. ONT, Router, etc. about 1/week. I have read that some people disable/enable Circle from the app.
Can you direct me to the instructions?
Also, is there an app out there that works properly?
- orbi-customerInitiate
I figured out how to disable Parental Controls in settings.
Then this morning - printer was not visible to computer so I disabled Circle, rebooted computer and printer, to no avail.
I looked at Armor Settings and turned that off and printer seems to be back. Issue might be Armor.
- Christian_RNETGEAR Employee Retired
Hi orbi-customer,
Thanks for reporting this and updating your thread.
Christian
