Orbi WiFi 7 RBE973
Reply
How to set connections to 17.253.16.125 as unmanaged time
roundincircles
Follower
I'm using Circle on my Orbi router. Circle is counting usage time while my kid isn't using her device. When I look at Usage History, the time used is for 17.253.16.125.
I looked up that IP address and it's an apple address that maps to aaplimg.com. I tried adding 17.253.16.125 and aaplimg.com as unmanaged in the Custom filter list but the time usage still accrues.
There's only one device in the affected profile. I have turned off auto updates on the iPad for iOS and the App Store and restarted the device and my router.
Any ideas on how I can configure circle to set connections to 17.253.16.125 as unmanaged time or stop the calls?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 676 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
