Orbi WiFi 7 RBE973
Reply
Missing parental controls on firmware v.2.7.2.104
pinecone123
Hi,
I just got my new Orbi RB50 (RBR50), finished the setup, updated firmware, and now I seem to be missing the parental controls in Orbi app on Android.
is that an issue with the firmware v.2.7.2.104? How do I get parental controls?
Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 84
riceale
Tutor
Re: Missing parental controls on firmware v.2.7.2.104
Same for me. Please fix.
Message 2 of 84
John_Ba
Luminary
Odd as it's on my app.
Message 3 of 84
alokeprasad
Mentor
Parental controls is gone from the web interface, but I see it on my iOS app (attached).
I haven't ventured any more in the app (because I'm not interested in the feature, and I don't want to mess up my setup).
Message 4 of 84
alokeprasad
Mentor
Here's the other screenshot.
Message 5 of 84
pinecone123
Is that on an iPhone or Android device? Do you see parental controls on the web interface?
Thanks
Message 6 of 84
pinecone123
Does parental controls feature work with iOS devices only ? Is there any way to enable it via the web interface? One of the selling points of RBR50 was parental controls.
Message 7 of 84
alokeprasad
Mentor
Thanks
iOS.
I don't see Parental Control option in the web interface.
Message 8 of 84
John_Ba
Luminary
I have in android and direct on router. I don't use it so I wonder if that's why?
Message 9 of 84
pinecone123
What firmware version do you use? Is your router RBR50 or RBR50v2?
Message 10 of 84
John_Ba
Luminary
My ones are V2
Message 11 of 84
Guru
I would reach out to NG support to ask them what the deal is. NG maybe moving away from Disney Circle and going to something of there own:
https://www.netgear.com/home/services/smart-parental-controls/
Good Luck.
Message 12 of 84
3BeansandDreams
I have the RBK50 v2 and firmware 2.7.2.104
It is missing on both the Web UI and IOS Orbi app.
Message 13 of 84
Guru
Good Luck.
Message 14 of 84
pinecone123
I reached out to NG supoort and got a generic reply to do a factory reset or downgrade firmware. The support person did not even give what I should downgrade to.
Message 15 of 84
Guru
I think v16 still supported Circle:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/tru...
Message 16 of 84
3BeansandDreams
I called as well. They want me to do a factory reset. Has anyone tried this yet? Did a factory reset fix the issue? Or did u have to lower the firmware?
I don’t want to lower the firmware. This will be a security issue.
Message 17 of 84
Guru
I don't see this on mine. Don't remember seeing it on v102 however you might try that version and see. It was suppoestly still on v102...
Message 18 of 84
bostonm3
I currently use Circle on my RBK50 Orbi Router/Satellite kit. The router is prompting me to upgrade but the newer firmware removes Circle support and replaces with Netgear Parental Controls. I downgraded back to v2.5.2.4 which is the last version that I was able to get Circle working.
Was there an annoucement that I missed where Netgear decided to end Circle support? The website still shows that Orbi comes with Circle.
Message 19 of 84
3BeansandDreams
Has anyone tried resetting their Router as suggested by CS? And did it work?
Message 20 of 84
Guru
Just reset mine, not seeing any parental controls:
Message 21 of 84
Guru
Just loaded v40 FW on my RBR and parental controls are available:
Message 22 of 84
Guru
Message 23 of 84
Guru
Looks like NG started taking out Parental Controls at v70:
Message 24 of 84
3BeansandDreams
Just did a complete reset on the Router and Satellite, Parental control no where to be found.
Don't really want to downgrade the firmware.  As updates fixes known security issues.
RBK50 V2
FW 2.7.2.104
Message 25 of 84
Top Contributors
Discussion stats
  • 83 replies
  • 6524 views
  • 19 kudos
  • 14 in conversation
Announcements
Orbi WiFi 7
