Reply
Moderators - Forum Post Broken?
DatabaseJase
Luminary
I've had some issues with my posts recently (only impacting the Circle Smart Parental Controls board I think) and this one doesn't have the solution which is a shame as I feel it might help people:
Solved: Circle Home Plus and Orbi RBR850 / AX6000 - NETGEAR Communities
I also posted similar content, linked to from that re-post, which didn't let me reply.
Please could someone investigate and fix? Thanks.
Message 1 of 4
Guru
Re: Moderators - Forum Post Broken?
Circle is not currently supported on Orbi AC systems. There has been no time frame or mention of it recently when it maybe supported. NG doesn't post that information.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 4
DatabaseJase
Luminary
I think you might have responded to the wrong topic as I didn't state that it was supported nor did I ask when it would be.
I'm simply asking for assitance regarding broken forum topics where I'm trying to provide useful information for people using the seperate, not Netgear specific, Circle Home Plus device with their Orbi AC system.
Message 3 of 4
Guru
Also was a typo, was meant to orbi AX. .
I would contact a forum moderator to ask about that link being broke. Either maybe bad or it was removed. Smiley Frustrated
Message 4 of 4
Discussion stats
  • 3 replies
  • 290 views
  • 0 kudos
  • 2 in conversation
Announcements
