Orbi WiFi 7 RBE973
Reply
Netgear R6400v2 - trying to configure Circle on router
rhawk204
I am trying to install the Circle app on my router - R6400v2. When I start the Circle app on my phone it says that it can't find Circle on my router. I checked the list to see if my router is compatible and it shows that it is.
Do I need to install or configure some software on my router before I start the circle app on my phone?
Thanks for any help.
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Netgear R6400v2 - trying to configure Circle on router
Hello rhawk204,
May you reinstall the app and check to see if your router is due for a firmware update as well.
https://www.youtube.com/watch?v=eJJbIKbQBCs
Christian
Message 2 of 3
rhawk204
Thank you. I will try to install the latest firmware on the router tomorrow.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1070 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
