Orbi WiFi 7 RBE973
Reply
ORBI (RBR50) Circle Passcode reset not sending SMS
GASM67
Hi,
Trying to get myself back into my circle and ask for text message to send code but nothing...
Can anybody help ?  Where can I get help for resetting the account.
Thanks in advance
G
Message 1 of 5
oshaughnessy
Initiate
Re: ORBI (RBR50) Circle Passcode reset not sending SMS
I'm having the same issue. I'd love to know if there's a way to start using Circle again.
Message 2 of 5
DexterJB
NETGEAR Moderator
Hi GASM67 and oshaughnessy,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 3 of 5
GASM67
Hi,
I think Dexter has probably helped by now, but in case not.
I manged to retrieve mine by first taking a back up copy of the settings.
Factory reseting the device, setting up the code again, then restoring from backup.
Hope that helps if you haven't already gotten it.
Graeme
Message 4 of 5
kaipus
we are not able to remember what is the 4digit passcode for circle, was trying to use the "sent sms" feature, but we got a "can't send sms, something went wrong".
is there a way to reset circle, so we can set it up again?
thanks,
Model: R7000|AC1900 Smart WIFI Router
Message 5 of 5
Discussion stats
  • 4 replies
  • 2340 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
