Orbi WiFi 7 RBE973
Reply
OpenDNS no longer available
waynegoodrich
Follower
Just updated to V1.4.1.42_1.3.4 firmware.  Was using OpenDNS, decided to try Disney Circle and don't like it.  How do I go back to having OpenDNS manage parental controls?
I have already tried factory reset and I don't seem to have an option other than Circle.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: OpenDNS no longer available
Hi @waynegoodrich, welcome to the community! Thank you for your feedback. If you wish to continue using the LPC (Live Parental Controls) feature, you will only be able to manage the settings via the desktop version of the Genie app which you can download on the link below and at the bottom click on DOWNLOAD PC or DOWNLOAD Mac.
https://www.netgear.com/home/discover/apps/genie.aspx
May we know what Circle feature does not work for you?
Dexter
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 929 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
