Orbi WiFi 7 RBE973
Reply
Orbi Netgear router alone without using the Circle App
Retired_Member
Not applicable
I am fully aware that I can see all my devices on the Orbi network through the Orbi app. Plus, I can turn wifi off and on through the Orbi app for individual devices. There just isn't an option for bedtime limits through the Orbi app alone."
So, is there a way to use Orbi Netgear router alone without using a foreign, ill-conceived and incompetent Circle app for bedtime control limits?
AC3000 WiFi Satellite (RBS50) Orbi Tri-band Add-on Satellite, 3Gbps
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Orbi Netgear router alone without using the Circle App
Hi kflocker,
I would like to introduce to you our NETGEAR Smart Parental Controls. Our NETGEAR Smart Parental Controls are built into select NETGEAR routers such as our RBR50. Please check out the links below for more info.
https://www.netgear.com/home/services/smart-parental-controls/#parental-control
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
Christian
Message 2 of 3
svetaketu
Luminary
Hi @Retired_Member,
Just to add to what @Christian_R said, you'll also need to make sure that you are using the latest RBR50: FW https://kb.netgear.com/000062857/RBR50-RBS50-Firmware-Version-2-7-2-104
Hope this helps.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1417 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
