Orbi WiFi 7 RBE973
Reply
Parental Controls - Orbi
OrbisUser95
Trying to figure out which model of Orbi to buy.  I want the strong parental controls that are availbale via the Circle App.  However, the top line Orbi systems don't have Circle.  Are the parental controls as good as Circle in the high speed wifi 6 tri-band systems?  AX4200 and higher models for example.
Message 1 of 3
Guru
Re: Parental Controls - Orbi
Circle has not been featured yet on Orbi AX. Circle is supported currently on Orbi AC models.
For help and information about Circle, please post in the circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/support/product/circle.aspx
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Good Luck.
Message 2 of 3
Beckysfamily
Tutor
Returning my AX4200 mesh system. There are no parental controls despite misleading advertising.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1179 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
