- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Parental Controls missing on RBR850
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental Controls missing on RBR850
So ethernet ports on RBS become non functional after they were updated? Did you factory reset the RBS after the FW update?
Ok the downgrade of the RBR is a known. Same thing for 7 series as well.
@ekhalil wrote:
@FURRYe38 wrote:
Just curious, are you able to downgrade back to v3 by chance?
No, The satellites are ok to downgrade to v3, but I could not downgrade the router to v3.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:So ethernet ports on RBS become non functional after they were updated? Did you factory reset the RBS after the FW update?
No, Ethernet ports are ok.
The problem is in the Router that can't recognize the wired satellites. Wired satellites can be added, but after restart they get permanently disconnected.
Factory resetting the satellites did not help.
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. I'll pass this on to NG for review. I'm kinda dreading updating to this version as my RBS are ethernet connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Ok. I'll pass this on to NG for review. I'm kinda dreading updating to this version as my RBS are ethernet connected.
Then don't upgrade to this software. I had to disconnect Ethernet on my 2 Satellites and use wireless backhaul instead.
Looking forward for a fix from Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok well, I'm a beta testers so I may have to udpate.
Any chance we could get some debug logs from you if they need some logging?
Are your RBS directly connected to the RBR or are there any LAN switches in between? If so, can you give brand and model#...
@ekhalil wrote:
Then don't upgrade to this software. I had to disconnect my 2 Satellites and use wireless backhaul instead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:....
Sure!
@FURRYe38 wrote:.....
I have direct cables from Router to the Satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok good. Thanks for the info. I'll see what they need if anything. Hate to see that feature be broken.
- « Previous
- 1
- 2
- Next »
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
