- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parental Controls not blocking internet when time expired or device paused
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently started the Parental Controls subscription, and I have created profiles for my kids and added their devices.
I set up time limits and bedtimes for both of them.
However when my kids time limit is used up, I get a notification but the wifi does not get blocked for my kids devices.
Bedtime does not pause internet either.
Also, when I manually pause internet on a device, it does not work. Internet (via WIFI) is still accessible on the device.
I've even tested by putting my own devices on a test profile, and that does not work either.
How do I get this working?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental Controls not blocking internet when time expired or device paused
We don't know what devices you are using, its firmware and other key details, so any answers here will be guesswork.
Is this Circle?
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah sorry
I've got
Netgear CM600 modem
Orbi RBR50 mesh wifi with 2 satellites
No circle, but I have the Smart Parental Controls subscription and the Armor subscription.
The one thing I have not done is install the My Time app on my kids devices.
Is that necessary to block wifi when their internet time is over? My understanding was that app was to block cell when away from wifi and for kids to see how much time they have left.
It seems logical that the wifi could be blocked on the router/wifi side without needed that app on the device.
I've restarted the router and wifi, no luck.
Any other suggestions?
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bcracchiola wrote:
I've got
Netgear CM600 modem
OK. The CM600 is not a part of the process. Those controls are, as you say, a router side thing.
@bcracchiola wrote:
No circle, but I have the Smart Parental Controls subscription ....
That is Netgear's third foray into "parental controls. First we had the free version (now on its way out). Then we had Circle. Now we also have several versions of Smart Parental Controls.
I assume that this is what you are talking about:
and then:
How do I set up and install NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
This means that this is probably the wrong bit of this place to seek help.
For a start the RBR50 isn't covered here.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
Then there is the separate section for this feature:
NETGEAR Smart Home Parental Controls - NETGEAR Communities
Sorry about the wild goose chase, but there won't be many people reading this who know anything about your device and this service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend you review this as well:
@bcracchiola wrote:Ah sorry
I've got
Netgear CM600 modem
thanks
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
