Orbi WiFi 7 RBE973
Reply
Problems on setting up circle on R8000P
Xfxy
Follower
I can set up circle
The app says my router is compatible for circle,but I cannot set it up
whats the problem?
Message 1 of 3
Re: Problems on setting up circle on R8000P
whats the problem?
Hard to tell without some information.
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @Xfxy, what part of the setup are you encountering an issue with?
Dexter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1074 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
