Orbi WiFi 7 RBE973
Reply
R6400 connect to circle
psallen
Follower
Disney Cirlce App shows that my router R6400 (AC1750) should have circle on my router.  When I try to connect via App it says "Darn, couldn't find circle on your Router."
Any suggestions?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
schumaku
Guru
Re: R6400 connect to circle
There exist at lest two different hardware versions - R6400(v1) Model R6400-100xxx vs. R6400v2 Model R6400-200xxx. Only the later one does support Circle in my opinion. Check your router product label. In case it's a R6400v2, ensure you have the current firmware in place - see https://netgear.com/support/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 967 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
