Orbi WiFi 7 RBE973
Reply
R7000 Circle with Disney not working
GaselGR
Guide
Hi, i istalled firmware version R7000 Firmware Version 1.0.9.30 - Hot Fix on my R7000.
I did a Factory settings restore i after that i find that Circle can not be enabled anymore.
Looking at
Circle Parental Control Info
 Agent Version:  and App Database Version: are completely blank.
So no Circle for 1.0.9.30.
Revert back to 1.0.9.28 restore proper Circle app versions and Circle is functional again.
Trying many times but it seems imposible to enable Circle in 1.0.9.30.
Please advise.
Thank you
Message 1 of 2
Jgueydan
Tutor
Re: R7000 Circle with Disney not working
You may have to do a restore to default inside your circle app. If that doesn't work, maybe try updating your router firmware, then do a factory restore on the router itself.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2140 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
