- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 NightHawk How To Dismiss Circle Blurb?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi - How can we remove the intrusive blurb every time we sign in to our router?
CIRCLE - Enable Smart Parental Controls on Your Router
We don't have need it or want it. It seems to have appeared with the latest firmware update.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
FINALLY -- THE SOLUTION APPEARED
Just to upgrade the firmware to V1.0.11.116_10.2.100, and the blurb is gone.
I did so, and it works. Negear's information follows:
Bug Fixes:
- Fixes possible system kernel panic issues.
- Fixes the issue where the attached device list displays incorrectly.
- Fixes the issue where the Circle ad window displays every time when logging in to web interface.
Download Link: https://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.11.116_10.2.100.zip
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 NightHawk How To Dismiss Circle Blurb?
Hi Sonya808,
Hope you're doing well! May you confirm the firmware version your router is currently on for us to better assist.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, Christian, for replying - The firmware is V1.0.11.110_2.1.38.1 . The blurb appeared with the latest firmware update. I contacted Mozilla support for Circle about removal. They ignored my question. I scoured the web. Some people advised to roll back to original factory defaults. That seems self-defeating. The firmware updates are for a good purpose.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Svetaketu,
Thank you for your advice! Yes, I have dismissed the blurb multiple times, but it always returns the next time I sign onto the router. I'd like to get rid of it permanently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SOLVED R7000 NightHawk How To Dismiss Circle Blurb?
Thank you for listening, and thanks to the developers who fixed this.
