Orbi WiFi 7 RBE973
Reply
R7000 circle time limits
howdymc
Time limits are not having an impact on Youtube viewing through Safari on an iPad.
All other applications seem to be blocked correctly via time limits.
We have removed the device from the child profile and added it back with no change.
Any suggestions?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: R7000 circle time limits
Hi @howdymc, welcome to the community! If you haven't yet, you can check the link below and see if setting custom filters will fix the issue.
https://support.meetcircle.com/hc/en-us/articles/115001381052-Using-Custom-Filters
Dexter
Message 2 of 4
howdymc
Thanks Dexter. I have checked that topic. The issue isn't that we are trying to block Youtube. We are OK with Youtube provided it's within the prescribed time limits. The issue is that no time limit seems to be impacting Safari browser usage on the iPad. It can be used past bedtime and past the time limit.
Any suggestions?
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @howdymc, I have sent you a message. Please check your inbox.
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1405 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
