- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000P & Circle
- Mark as New
- Bookmark
- Subscribe
- Permalink
R8000P & Circle
Online literature seems to suggest that the R8000P supports Circle. I’ve set up my new router but cannot get it to work.
Am I missing something? Or is Circle not supported yet?
Thanks,
Dan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi,
So far, R8000P can't support Circle Partental control.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
I guess I’ll need to return it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi GreenYamo,
Let me explain more detail;
R8000 x6 do support Circle.
R8000P X6S will support Cirlce in the feature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Don’t suppose you’ve got any idea when it’s due? Or if there’s a beta firmware with support?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi GreenYamo,
If you would like to try, I will be very happy to provide trial FW to you.
Moreover, did you use Android device or iOS ?
This function also contorled by app, not only router FW.
I suggest you keep R8000P since it's a good product to use.
Ex: Wifi coverage, stable performance....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
I had an r7000p but found it to be unstable. First impressions of this router are really good. I’ve installed the Up app, and I’ve browsed through the website settings too.
It does everything I need, with the big exception of the Circle/Parental scheduling stuff. Circle worked great on the r7000p.
I’ll happily install the trial and give that a go.
Thanks for all your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
I am also interested in obtaining Circle for the r8000p
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Will the beta firmware with circle works on R7900P? I am interested in testing that out also.
Thanks!
Ray
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
I will be interested in the beta firmware to enable circle, I actually purchase this router today knowing the X6 support Circle and also that the X6S was better.
To realize it is not supported! So that's my only hope, or I will return it and buy an circle addons instead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Netgear's silence is deafening here.
I've returned the router at this point. I've had issues with the 2.4ghz network dropping unexpectedly. I've also read numerous reports of instability with this router and others.
My previous experience with the R7000p, combined with this router, have put me off Netgear for a while.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi,
So far, I just can provide android apk and FW for trial use.
Android app 2.0.103 - https://drive.google.com/file/d/0B2EzTtGXuQeFVU1qTE5NOWY4Vzg/view
FW: https://www.dropbox.com/s/jfjzm217az3ggpe/R8000P-V1.3.0.6_1.1.99.chk?dl=0
Just for Circle function trial .......Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi GreenYamo,
I feel so sorry to got this information.
Did you provide your message and confie file to support team ?
netgearteam@netgear.com
We will support to solve issue undoubtedly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Is there a beta or timeframe for IOS capabilities?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi @DjRiDe,
Welcome to the community!
The links below may help. As it stands, the R8000P is not among the models that support Circle.
https://kb.netgear.com/000044718/
http://www.netgear.com/landings/circle/
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Hi i am nw to this community. I need to replace my old wndr3700 Netgear router
I was intending to replace by R8000P BUT I do need Circle for parental control.
My preference is R8000P instead of the older R8000. The R8000P is 64 bit chip architecture, and
you buy a new router for more then 1 or 2 years. So R8000P has preferences above R8000
Is there already Beta FW for the R8000P?
Is there any idea how long it will take before Circle will work with R8000P?
When the Beta FW is already there, I will buy the R8000P and i am willing to test the FW and give
feedback to the development team. (I am working in the IT industry and am used to work like this)
Greetings,
Cor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Not very sure how long you have to wait until NG really implement Circle on R8000P. Not even sure whether that option is a wise one, until NG really figure it out the very existing problem with wireless disconnection on R8000P.
Not sure whether there is a beta FW, neither.
Things are still in limbo for R8000P.
I personally acquired a used one from one of the forumers here with known fw problem to try to mess around with. So far unsuccessful due to my time restraint committing to other NG project. I will resume my task with R8000P soon.
In short, please do not expect any progress regarding Circle implementation on R's routers (except the ones already have). NG parental controls features does not fare very well, including open DNS.
My R8000 works perfectly fine, with no internet loss problem and any other problems at all, using recent older fw,
Best
Terry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
Also the wifi performance seem really unstable and poor for the price. I need to reboot the router every time the Wan speed on wifi is slow and it works for a while.
So at this price, it's a total rip-off. I'm actually look to replace it a year after getting it..
Buy something else that have better review on stability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P & Circle
windsaga, I would love to test this APK and FW for Circle support, if still available. The link in your post for FW is no longer functional
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
