Orbi WiFi 7 RBE973
Reply
Timie Limits with Playstation?
Atlixnor
Guide
IS it not possible to set a time limit? Seems I can only set Offtime or Bedtime applying to that device.
IS it not possible to add the same device to two children at the same time? Seems so.
When I first enabled Circle, the PS4 stopped working, so I removed it from Circle management. Will I now get this problem back? OR is there a way around?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Timie Limits with Playstation?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 862 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
