Orbi WiFi 7 RBE973
Reply
Unable to receive passcode text - please help reset
L1TEMUP
Initiate
I've tried disabling/enabling circle, rebooting router, and reinstalling mobile app. Nothing i try will send the passcode text message to my phone. Please help me reset.
Message 1 of 3
DexterJB
NETGEAR Moderator
Re: Unable to receive passcode text - please help reset
Hi @L1TEMUP,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 2 of 3
bpacqu0
Hi I'm having the same issue. Did you figure this out?
I bought the nighthawk router with Circle and the initial setup was fine, even created my circle profile on my android, but since then it keeps asking for a pin. It doesn;t accept the one i set up nor does it send the pincode to my mobile number that I set up on my profile.
Its driving me crazy. I hope you've resolved this and can share how to fix this.
Model: R7000P | AC2300 Nighthawk Smart WiFi Router with MU-MIMO
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1555 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
