- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Why do kids phones move from managed to unmanned on Circle?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Kjones1998,
Welcome to the community!
You can check and make sure that they don't have Circle installed on their devices and then go through the setup again and select the option "I'm the only admin" as described on the link below.
You can then setup a PIN lock as described here:
https://support.meetcircle.com/hc/en-us/articles/115001382211-Using-the-Circle-App-Lock-PIN
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Kjones1998,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Why do kids phones move from managed to unmanned on Circle?
Great! also, when I try to change the admin password to the router I get stuck too. I know that I go to the login page but when I type in the serial number the "continue" button does not function. Could you tell me about this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When trying to access the router UI, you should be prompted for the username and password and not the serial number. Have you tried using another device in getting to the router UI?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Kjones1998,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
