Orbi WiFi 7 RBE973
Reply
filter youtube
JasonJe
Follower
filter youtube
I have the R7000P netgear with the Circle parental controls running on it, managed by the Gen1 APP. I can not get it to block or filter youtube, despite explicitly doing so in the App. I have confirmed I can pause the devices connection with the pause button, therefore circle sees the device and can enforce a rule. It appears most of the predefined filters, i..e youtube, netflix, etc do not work. Any thoughts or guidance would be welcome!
Thanks!
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: filter youtube
Hi JasonJe,
May you check to see if your router is due for a firmware update. You may also reinstall the Circle/Nighthawk app.
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 828 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
