Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Advice compiling php
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-05
09:36 AM
2012-12-05
09:36 AM
Hello,
I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2=
The only apxs file I found in the readynas duo was located in /c/home/admin/support/apxs.
But when viewing the content of apxs I seems that the paths are set wrong. Anyway, when using "../php-5.3.10/configure --with-apxs2=/c/home/admin/support/apxs --host=sparc-linux I'll get
Have I to correct all paths? Is there a newer apxs file available? Or is there an other workaround to get the php compiled with using the apache version of the readynas duo? greetings
Sorry, I cannot run apxs. Possible reasons follow:
1. Perl is not installed
2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs
3. Apache was not built using --enable-so (the apxs usage page is displayed)
The output of /c/home/admin/support/apxs follows:
sh: line 1: /usr/local/apache2/bin/envvars: No such file or directory
apxs:Error: Sorry, no shared object support for Apache.
apxs:Error: available under your platform. Make sure.
apxs:Error: the Apache module mod_so is compiled into.
apxs:Error: your server binary `/c/home/admin/'..
configure: error: Aborting
Message 1 of 15
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-05
09:47 AM
2012-12-05
09:47 AM
Re: Advice compiling php
WhoCares will probably have some input, he went through those growing pains awhile ago.
Do you need specific customized stuff? Looked at viewtopic.php?f=47&t=54543 ?
Message 2 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-07
10:37 AM
2012-12-07
10:37 AM
Hello, I need some customized extensions like mapi (for zarafa) and the pgsql extension. greetings
Message 3 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-07
04:30 PM
2012-12-07
04:30 PM
http://readynasxtras.com/forum/viewtopic.php?f=17&t=57
http://readynasxtras.com/forum/viewtopic.php?f=17&t=18
Might be more too, those are just from memory.
Message 4 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-12
09:13 AM
2012-12-12
09:13 AM
Hi,
thanks for the replies. I'm able to compile php php-5.4.9 without the parameter --with-apxs2=/c/home/admin/support/apxs with my gcc 4.6.0 + upgraded tools.
Configuring php with ../php-5.3.10/configure --exec-prefix=/usr/lib/apache2 --with-apxs2=/c/home/admin/support/apxs --host=sparc-linux will break at:
As we know Perl is installed on the readynas duo. In addition I figured out that apache2 was compiled with enable-so (checked with apache2 -l). The message "sh: line 1: /usr/local/apache2/bin/envvars: No such file or directory" is confusing.
I edited /homes/admin/support/apxs and changed the paths to:
An other problem is that printing perl variables in the apxs file will be suppressed. So maybe I have to create a seperated perl script to dump "
The config.log last line is:
and doenst support any more information 😞
Another idea whould be to create the missing folders and copy the apache files into these directories? But first I will try to dump the perl variables and look forward.
greetings and best regards
checking for Apache 1.x module support... no
checking whether to enable Apache charset compatibility option... no
checking for Apache 2.0 filter-module support via DSO through APXS... no
checking for Apache 2.0 handler-module support via DSO through APXS...
my $installbuilddir = "/usr/sbin/apache2"; ##"/usr/local/apache2/build";so the paths should be correct. Why is it me telling that the path in "sh: line 1:" / is incorrect? This is a perl script and not a shell script. Is it possible that the error does not occour in the apxs file, because the error is in a shell script on line 1? 0o Or am I searching the error in the wrong file?
##get_config_vars("$installbuilddir/config_vars.mk",\%config_vars);
get_config_vars("/c/home/admin/build/config_vars.mk",\%config_vars);
my $httpd = get_vars("sbindir") . "/" . get_vars("progname");
$httpd = eval qq("$httpd");
my $envvars = get_vars("sbindir") . "/envvars";
$envvars = eval qq("$envvars");
configure:5271: checking whether to enable Apache charset compatibility option
configure:5438: checking for Apache 2.0 filter-module support via DSO through APXS
configure:6327: checking for Apache 2.0 handler-module support via DSO through APXS
Message 5 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-06
01:37 PM
2013-01-06
01:37 PM
If it helps, I could provide you with the complete Apache .deb packages for the ReadyNAS. Of course you could also compile them from the GPL sources yourself. Using the apxs2 from that package should fix your problem I guess.
-Stefan
-Stefan
Message 6 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-07
01:35 PM
2013-01-07
01:35 PM
Thanks, I would like to use your apxs2 file and then try to compile it by my self. 🙂
greetings
greetings
Message 7 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-10
01:55 PM
2013-01-10
01:55 PM
Since I couldn't upload them here, you'll find the packages there: http://readynasxtras.com/forum/viewtopic.php?f=18&t=2555
-Stefan
-Stefan
Message 8 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-13
11:32 AM
2013-01-13
11:32 AM
Thanks Stefan.
I successfully compiled php-5.4.9 with your apxs2 btw. the unpacked apache2-prefork-dev_2.2.6-2.netgear2_sparc.
I used the following configure
../php-5.4.9/configure '--with-config-file-path=/etc/php5/cli/php.ini' '--with-config-file-scan-dir=/etc/php5/cli/conf.d' '--enable-calendar' '--enable-bcmath' '--with-pgsql=/usr/local/pgsql' '--exec-prefix=/usr/lib/apache2' '--with-apxs2=/c/home/admin/support/apxs2' '--host=sparc-linux' '--build=sparc-linux' '--with-gnu-ld' '--prefix=/usr' '--mandir=/usr/share/man' '--without-iconv' 'build_alias=sparc-linux' 'host_alias=sparc-linux'
I also had to create a symlink in /etc/apache2/httpd.conf -> /etc/frontview/apache2.httpd.conf
greetings
[Edit]
If you want to compile an older version of php for example 5.3.10 you run into the issue, that configure will include ieefph.h into main/php_config.h and unix.h which results in an compiler error because this files doesn't exists on the readynas duo. Just uncomment unix.h and ieeefph.h in nano main/php_config.h and it should work.
greetings
[Edit]
Message 9 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-13
12:53 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-05
06:45 AM
2013-02-05
06:45 AM
Hi,
I got here some dependcy problem with apt-get and want to ask if i can do apt-get install -f without breaking the apache:
fes-a120d19nas:/backup/fes-a120d19nas/zarafa/gss-0.1.5# apt-get install -f
Reading Package Lists... Done
Building Dependency Tree... Done
Correcting dependencies... Done
The following extra packages will be installed:
libexpat1-dev libgnutls11 libldap2 libldap2-dev liblzo1 libopencdk8 libpcre3-dev libpcrecpp0 libsqlite3-dev libtasn1-2
Suggested packages:
gnutls-bin sqlite3-doc
The following packages will be REMOVED:
apache2-prefork-dev libapr1-dev libaprutil1-dev
The following NEW packages will be installed:
libexpat1-dev libgnutls11 libldap2-dev liblzo1 libopencdk8 libpcre3-dev libpcrecpp0 libsqlite3-dev libtasn1-2
The following packages will be upgraded:
libldap2
1 upgraded, 9 newly installed, 3 to remove and 75 not upgraded.
3 not fully installed or removed.
Need to get 1693kB of archives.
After unpacking 1847kB disk space will be freed.
Do you want to continue? [Y/n]
Message 11 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-05
12:56 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-05
01:16 PM
2013-02-05
01:16 PM
Long answer: Really! Don't do this! I mean it! #notsupported #borked #noGUI
Message 13 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-06
07:41 AM
2013-02-06
07:41 AM
Is there a nice way to solve this issue? I want to execute apt-get install libgsasl7 which breaks because of the above depency problems.
Message 14 of 15
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-06
07:49 AM
2013-02-06
07:49 AM
The only way to solve this is to recompile manually from the source packages and changing the dependencies there.
-Stefan
-Stefan
Message 15 of 15
