× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Bzeeet
super_poussin
Virtuoso
Bzeeet
BZeeet
  • Description: Index your files on network (smb,local,ft).
  • Requirements: RAIDiator 4.1.3+ and PHP add-on and MySQL add-on
  • Platform: DUO NV+
  • Current Version: 1.2
    Bzeet (10/08/09)
    • search files using a web interface
    • modify files ending with .config.php in /c/webroot/bzeeet/crond/ to adapt to your wishes
    • No password on admin panel
    • Installation Notes:
      you need to install PHP addon if not already done
      in some case your nas will not able to contact your servers on your lan using netbios name if the router or your dns did not provide short name resolution. in this case you will need to edit you /etc/hosts file
    • Screenshots:
    • Old Versions:
      removed
Message 1 of 2
super_poussin
Virtuoso
Re: Bzeeet
1)after instal a 1st indexation is launched so be patient
2) if you have a language error try http://nasip/bzeeep/index.php?lang=fr or lang=en or lang=de ....
of course replace nasip with the @IP of your NAS
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3894 views
  • 1 kudo
  • 1 in conversation
Announcements
