Reply
Virtuoso
Bzeeet
BZeeet
  • Description: Index your files on network (smb,local,ftp).
    Bzeeet is a stable and flexible Desktop-Files/SMB/FTP crawler and search engine.
    It can be used to index documents stored :
    •on your own computer to find them faster,
    •on a NAS storage device using SMB/CIFS,
    •on a remote FTP server where SMB doesn't work,
    •on a wide local network (in a company for example)
  • Requirements: RAIDiator 4.2.3+ and PHP add-on and MySQL add-on
  • Platform: PRO/NVX
  • Current Version: 1.1
    Bzeet (07/19/09)
    • updated to bzeet 2.2.1
    • search files using a web interface
    • modify files ending with .config.php in /c/webroot/bzeeet/crond/ to adapt to your wishes
    • No password on admin panel
    • Installation Notes:
      you need to install PHP addon if not already done
      in some case your nas will not able to contact your servers on your lan using netbios name if the router or your dns did not provide short name resolution. in this case you will need to edit you /etc/hosts file
    • Screenshots:
    • Old Versions:
      Bzeet (12/28/08)
    • Credits and Sources:
      Bzeet
If you like my add-ons - Si vous aimez mes add-ons :
EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
Where I'm teaching
4B Perros
Virtuoso
Re: Bzeeet
1.1 is out
Where I'm teaching
4B Perros
Discussion Stats
  • 1 reply
  • 1570 views
  • 0 kudos
  • 1 in conversation
