× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Cacti
super_poussin
Virtuoso
Cacti
CACTI
  • Description: Cacti is a complete network graphing solution designed to harness the power of RRDTool's data storage and graphing functionality. Cacti provides a fast poller, advanced graph templating, multiple data acquisition methods, and user management features out of the box. All of this is wrapped in an intuitive, easy to use interface that makes sense for LAN-sized installations up to complex networks with hundreds of devices.
  • Requirements: RAIDiator 4.2.1+
  • Platform: X86
  • Current Version: 1.9
    Removed (07/24/10)
    • Better check of php installation (should solve frontview crash in some rare case)
    • Include all files for PHP support no more need to install PHP first it's a all in one
    • Cacti can now be disabled
    • UPS Monitoring (10/26/08)
    • X86 fans and T° monitoring
    • Cacti is now located in /c/webroot/cacti
    • Readynas templates are in /c/webroot/cacti/Readynas
    • Monitor and Discovery plugins are included (configure it to the the tab in settings/misc)
    • NV+/duo/1100 fans and T° monitoring (10/26/08)
    • Based on 0.8.7.e
    • plugin support added
    • Installation Notes:
      user is admin with password : admin
      after installing and first login you will see some error message to avoid it enable snmp in the cacti global configuration
      you must import xml files located in webroot/cacti share in Cacti UI 🙂
    • Screenshots:
Message 1 of 4
super_poussin
Virtuoso
Re: [PRO] Cacti
updated 10/26/08
Message 2 of 4
super_poussin
Virtuoso
Re: Cacti
updated
Message 3 of 4
super_poussin
Virtuoso
Re: Cacti
updated
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5220 views
  • 0 kudos
  • 1 in conversation
Announcements
