bacobart's avatar
bacobart
Compiling kernel modules for 6.1.9 fails
I've recently updated to 6.1.9 and am now trying to recompile my kernel modules for this kernel. I'm using the kernel from http://www.downloads.netgear.com/files/GPL/ReadyNASOS_V6.1.9_WW_src.zip. My device is a ReadyNAS 516.
Whatever I try, my modules always end up incompatible: modprobe results in <module>: disagrees about version of symbol module_layout
I've compiled the kernel by using "make ARCH=x86_64" and "make ARCH=x86_64 modules". I've also tried to copy ./arch/x86/configs/defconfig.x86_64 to .config and arch/x86/configs/readynas_defconfig to .config before compiling. This used to work with readynasos 6.1.8 and before. So I'm starting to think that the kernel/config included in the 6.1.9 zip file isnt the one thats now actually running on my device. Could this be true, or am I doing something wrong?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    What kernel version is in the GPL sources?
    Does that match the version on your NAS. We did update the kernel in 6.1.9.
  • linux-3.0.101-0.15 is what's included in 6.1.9.zip. That's the same folder name as in 6.1.8 -- also the .config in 6.1.8.zip and 6.1.9.zip are the same. So looks like 6.1.9.zip doesnt include the proper kernel/config then?
    mdgm-ntgr
    Yes. We will need to re-release the GPL code for 6.1.9 with the correct kernel.
  • Skywalker's avatar
    Skywalker
    NETGEAR Expert
    The official page will take a little more time to be updated, but in the meantime you can grab it from here.
  • I've been able to successfully compile the kernel modules with the linux-3.0.101-0.35 kernel included in the update zip. Much appreciated, thank you!
    FYI, the zip now includes both kernel linux-3.0.101-0.15 and linux-3.0.101-0.35 -- I'm not sure if that is intended.
  • Hi,
    Official link for 6.1.9 GPL sources is still not up to date - http://kb.netgear.com/app/answers/detail/a_id/2649/related/1
    I lost one evening before to dig into the forum and find this topic...
    mdgm-ntgr
    When did you download the GPL from the kb.netgear.com site?
ProSupport for Business
