Reply
Prodigy
CouchPotato 0.4.0r35
[ Edited ]
    • Description:
      CouchPotato (CP) is an automatic NZB and torrent downloader. You can keep a "movies I want"-list and it will search for NZBs/torrents of these movies every X hours. Once a movie is found, it will send it to SABnzbd or download the torrent to a specified directory.
    • Requirements: RAIDiator 4.2.15+ (may work with earlier versions but that's untested)
      For this add-on to work,the Python2.6 add-on has to be installed on your ReadyNAS.
    • Platform: Intel
    • Features:
        • Can be upgraded right on the ReadyNAS
        • Automatic downloading and sending of NZBs to SABnzbd
        • Automatic downloading of torrents files to a specified directory
        • Easily add movies via IMDB UserScript
        • Movie sorting & renaming
        • Trailer downloading
        • Quality options to download best available. Overwrite if better is found.
        • A "Coming Soon" page with soon to be released DVD and Theater info.
      • Support for NZBs.org, NZBMatrix, Newznab.com and ThePirateBay.
    • Changes in this release:
      - Update to the latest revision from GitHub
      - Fixes a problem with the extern videoeta.com service
      - Fixes a problem where updates from within the application weren't possible anymore
      - Fixes a problem where removing the add-on from within Frontview wouldn't work properly
  • Details/Installation:
      • After installation of the add-on, CouchPotato's web interface can be accessed by typing http://<ip of your NAS>:5000/ in your browser's address field.As an alternative you can use the quick link from the add-on's section in the "Services" -> "Installed Add-ons" tab within Frontview. You will be presented with a login screen.
      • The default username is admin with a default password of netgear1.
    • After logging in with these credentials please configure CouchPotato to your needs - don't forget to change your password Smiley Wink
Follow me on Twitter, Facebook, Google+ or visit my add-on web site
Prodigy
Re: CouchPotato 0.40
Updated to: CouchPotato 0.40 v0.1.4
- Fixes a problem where the SABnzbd integration could accidentally remove the API key for "TheMovieDB" from CouchPotato's config, thus making movie lookups from that souce impossible.
Prodigy
Re: CouchPotato 0.4.0r35
Updated to: CouchPotato 0.4.0r35 v0.2.6
Discussion Stats
  • 2 replies
  • 2171 views
  • 0 kudos
  • 1 in conversation
Top Contributors
