× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Docker CLI App for 6.7.0 (Work In Progress)
Mhynlo
Luminary
It looks like there are some handy changes in 6.7.0, so I tried to get a Docker CLI app to get the containers moved over into the apps directory (not root volume).
https://community.netgear.com/t5/Community-Add-ons/ReadyNAS-Apps-6-7-0-Update/m-p/1235247
The app needs the kernel plus app to work properly. I suspect this should work fine on the 6.7.0 Beta 2 or something. I am running the T172 intern build and it is not able to install kernel plus.
Here is the Docker CLI package that I have so far
https://github.com/Mhynlo/readynas-docker-cli/releases
I am looking into some UI options for Docker to make it easer for the people that are afraid of a little CLI. There appears to be a lot of options. I am looking at Portainer or Rancher, but wanted to hear if anyone heard of any other good Docker UI options that are available out there.
Message 1 of 7
OOM-9
NETGEAR Expert
Re: Docker CLI App for 6.7.0 (Work In Progress)
You can try downgrading to the Beta 2 to get the support for the Kernel Plus app. The fix for the 6.6.1 that was in the intermediate build will be kept when downgrading to the Beta 2 build. We try to make sure the the dependent package for Kernel Plus is available for the public betas.
Message 2 of 7
Mhynlo
Luminary
It looks like Docker is changing their packaging over to a different repo and versioning. I have updated the latest package to work with the newer version.
I downgraded to beta 2 and I am able to run the latest docker.
Download available:
https://github.com/Mhynlo/readynas-docker-cli/releases/tag/17.03
Message 3 of 7
Guru
thx for keeping us up to date on your progress here.  Docker support will be very helpful.
Message 4 of 7
Mhynlo
Luminary
I am still looking into implementing the UI bit.
I looked at Potainer. It looks like they are partnering with Rancher, so time to look at Rancher!
https://twitter.com/portainerio/status/837902857022033921
Message 5 of 7
Mhynlo
Luminary
I looked into the Rancher option, and it looks like that might be better suited with a server with more resources. Portainer is a little more lightweight and provides a lot of useful features/interfaces to docker.
I have set it up to require the Docker-CLI package to be installed since that handles all of the volume management for the docker containers. Portainer is running as a container within Docker, so they are tightly related.
Here is the Portainer release that works with the 6.7.0 betas:
https://github.com/Mhynlo/readynas-portainer/releases/tag/1.12.1
Message 6 of 7
MrGamerChoi
Tutor
Thx for the hard work! Keep it up mate.
Will try this out once I finished backing up my data. I screwed my Admin page up when I installed rutorrent on my 102 and I heard it may works fine under Docker. Will let you know if it works or not.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3819 views
  • 0 kudos
  • 4 in conversation
Announcements
