Reply
Virtuoso
DynDns
Dyndns Client
  • Description: DynDns client will let you update your dyndns host with your internet IP
  • Requirements: RAIDiator 4.1.3+
  • Platform: NV/NV+ - DUO - 11000
  • Current Version:1.0
    DynDns (10/21/08)
    • Does Not Support SSL
    • supports : easydns, zoneedit,...
      Full Features
  • Installation Notes: please read carefully
    1) After installing you must disable the service
    2) then edit the ddclient.conf in webroot/ddclient share
    3) then activate the service
  • Syntax example: Do not touch the line daemon,pid,cache,ssl, use
    # Basic HTTPS configuration file for ddclient
    daemon=600
    pid=/var/run/ddclient.pid
    cache=/ramfs/ddclient.cache
    ssl=NO
    use=web, web=checkip.dyndns.com/, web-skip='IP Address'
    login=your-username
    password=your-password
    protocol=dyndns2
    server=members.dyndns.org
    wildcard=YES
    example.dyndns.org
    example for other providers:
    ## ZoneEdit (zoneedit.com)
    # server=www.zoneedit.com, \
    # protocol=zoneedit1, \
    # login=your-zoneedit-login, \
    # password=your-zoneedit-password \
    # your.any.domain,your-2nd.any.dom
    ## EasyDNS (easydns.com)
    # server=members.easydns.com, \
    # protocol=easydns, \
    # login=your-easydns-login, \
    # password=your-easydns-password \
    # your.any.domain,your-2nd.any.domain
    ## Hammernode (hn.org) dynamic addresses
    # server=dup.hn.org, \
    # protocol=hammernode1, \
    # login=your-hn-login, \
    # password=your-hn-password \
    # your-hn-host.hn.org,your-2nd-hn-host.hn.org
    ## dslreports.com dynamic-host monitoring
    # server=members.dslreports.com \
    # protocol=dslreports1, \
    # login=dslreports-login, \
    # password=dslreports-password \
    # dslreports-unique-id
    ## OrgDNS.org account-configuration
    # use=web, web=members.orgdns.org/nic/ip
    # server=www.orgdns.org \
    # protocol=dyndns2 \
    # login=yourLoginName \
    # password=yourPassword \
    # yourSubdomain.orgdns.org
    ## dnspark.com
    ## (supports variables: mx, mxpri)
    # use=web, web=ipdetect.dnspark.com, web-skip='Current Address:'
    # protocol=dnspark, \
    # server=www.dnspark.com, \
    # your-host.dnspark.com
    ## NameCheap (namecheap.com)
    # protocol=namecheap, \
    # server=dynamicdns.park-your-domain.com, \
    # login=my-namecheap.com-login, \
    # password=my-namecheap.com-password \
    # myhost.namecheap.com
    it supports firewall and router usage for IP detection (by default it use web request )
    #use=watchguard-soho, fw=192.168.111.1:80 # via Watchguard's SOHO FW
    #use=netopia-r910, fw=192.168.111.1:80 # via Netopia R910 FW
    #use=smc-barricade, fw=192.168.123.254:80 # via SMC's Barricade FW
    #use=netgear-rt3xx, fw=192.168.0.1:80 # via Netgear's internet FW
    #use=linksys, fw=192.168.1.1:80 # via Linksys's internet FW
    #use=maxgate-ugate3x00, fw=192.168.0.1:80 # via MaxGate's UGATE-3x00 FW
    #use=elsa-lancom-dsl10, fw=10.0.0.254:80 # via ELSA LanCom DSL/10 DSL Router
    #use=elsa-lancom-dsl10-ch01, fw=10.0.0.254:80 # via ELSA LanCom DSL/10 DSL Router
    #use=elsa-lancom-dsl10-ch02, fw=10.0.0.254:80 # via ELSA LanCom DSL/10 DSL Router
    #use=alcatel-stp, fw=10.0.0.138:80 # via Alcatel Speed Touch Pro
    #use=xsense-aero, fw=192.168.1.1:80 # via Xsense Aero Router
    #use=allnet-1298, fw=192.168.1.1:80 # via AllNet 1298 DSL Router
    #use=3com-oc-remote812, fw=192.168.0.254:80 # via 3com OfficeConnect Remote 812
    #use=e-tech, fw=192.168.1.1:80 # via E-tech Router
    #use=cayman-3220h, fw=192.168.0.1:1080 # via Cayman 3220-H DSL Router
    #fw-login=admin, fw-password=XXXXXX # FW login and password
    ## To obtain an IP address from FW status page (using fw-login, fw-password)
    #use=fw, fw=192.168.1.254/status.htm, fw-skip='IP Address' # found after IP Address
  • Old Versions: none
    Many thanks to the jedi for helping me
  • If you like my add-ons - Si vous aimez mes add-ons :
    EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
    Where I'm teaching
    4B Perros
    Discussion Stats
    • 0 replies
    • 4393 views
    • 0 kudos
    • 1 in conversation
    Top Contributors
