× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Edited posts get removed?
LaszloFolgerts
OK, since there's no proper place to adress problems regarding the functionality of the forums, I'll just post it in the same category as where the bugs happened.
It seems that every time I try to edit a reply, when I hit "post" in the edit window, I get redirected to the "threads list,"  where you see all the thread of the category you're in (not sure what the proper name is for that) and when I then go back to the thread where I wanted to edit the reply, the reply is gone. This has happened quite a few times now.
Also, in one of my own threads, I tried to edit one of my replies which I had selected as a solution, so now that solution is also gone and the link in the thread that says "go to solution" is now dead.
Is anyone aware of tthese bugs?
Message 1 of 3
Guru
Re: Edited posts get removed?
I frequently edit my posts, and haven't seen this.
You should report this as a bug in this forum: https://community.netgear.com/t5/Community-Suggestions/bd-p/community-suggestions
Please include the browser and the OS you are using.
Message 2 of 3
KennethL
NETGEAR Employee Retired
Moved:
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3313 views
  • 0 kudos
  • 3 in conversation
Announcements
