Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Installing Perl Based Package
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-08
06:06 PM
2012-12-08
06:06 PM
I'm having a heck of a time installing a perl based package (etree-scripts: https://launchpad.net/~ketilwaa/+archive/etree-scripts/+packages). I've made my way through a few problems so far. At first I was getting this:
Based on some Google'ing I did the following:
Which then led to this:
I found a discussion here that pointed to the following package, so I did this:
Then I could at least run Makefile.PL on ExtUtils, but when I got to the Make step, I get this:
I get the same message if I try to Make on the etree-scripts package. I Google'd this for awhile and all of the suggestions seemed to be dead ends to me. Any suggestions? I use Linux quite a bit, but when it comes to this type of manipulation, I consider myself a novice. I looked in /usr/lib/perl/5.8/CORE, and there are no contents to that directory.
I found this thread: http://www.readynas.com/forum/viewtopic.php?f=35&t=58321, but when I do CPAN -v, I just get cpan: command not found.
Thanks for any advice!
perl Makefile.PL
Can't locate ExtUtils/MakeMaker.pm in @INC
wget http://files.directadmin.com/services/9.0/ExtUtils-MakeMaker-6.31.tar.gz
tar xvzf ExtUtils-MakeMaker-6.31.tar.gz
cd ExtUtils-MakeMaker-6.31
perl Makefile.PL
Can't locate DirHandle.pm in @INC
wget http://www.readynas.com/packages/readynas/perl-modules_5.8.8-7.infrant2_all.deb
dpkg-deb -x perl-modules_5.8.8-7.infrant2_all.deb /
make: *** No rule to make target `/usr/lib/perl/5.8/CORE/config.h', needed by `Makefile'. Stop.
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-10
01:04 PM
2013-01-10
01:04 PM
Re: Installing Perl Based Package
I found your post via Google, and evntually found the last post on this thread to sort CPAN:
Hope it helps 🙂
Hope it helps 🙂
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-10
01:33 PM
2013-01-10
01:33 PM
Instead of manually installing all the missing packages one could probably just do an "apt-get install perl-modules" (provided the needed APT add-on is already installed). This should also install the CPAN module.
-Stefan
-Stefan
Message 3 of 3
