× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
LLINK 3.0
super_poussin
Virtuoso
LLINK 3.0
LLINK
  • Description: Media Streamer for Syabas Platform
  • Requirements: RAIDiator 4.2.3+
  • Platform: PRO/NVX
  • Current Version:3.0
    Llink 2.2.2 (11/04/10)
    Llink (01/18/09)
    • based on llink 2.2.2
    • correct skin location problem
    • you can know modify the llink.conf without ssh access (llink.conf is under webroot/llink/ share)
    • Added UDF2.50 support to dvdread for BD-5 ISO images. (HD-DVD as well, in theory)
    • Added support to UDF list files (instead of just domain,title DVD lookup)
    • Jukebox page 2 and up incorrectly handled Separator for files.
    • libdvdnav fails to open paths with /VIDEO_TS/. Reverted function from libdvdread.
    • Changed pass=0 to list and cache only. Pass=1+ simply replays cache. No need for lastline etc.
    • Fix history code so parent sets from page and focus correctly.
    • Fix focus setting
    • Add user-set sort-types in conf
    • Add sort-by cgi key, and MACROS to control sorting.
    • Fixed SSDP to also work against xbox360 and Playstation3 (query only, more work needed for actual use)
    • Added option to automatically expand RAR files when listing.
    • Added option to automatically expand ISO files when listing.
    • Added option to allow sending of index.html file if present in directory
    • New MACROs for current page, tvid-tvid and total pages, total files.
    • Minor changes in extra-info, directory.ext was terminated at .ext
  • Installation Notes: none
  • Screenshots:
  • Old Versions: initial release
  • Credits and sources :
    LLink
  • Message 1 of 2
    super_poussin
    Virtuoso
    Re: LLINK 3.0
    updated as requested
    Message 2 of 2
    Top Contributors
    Discussion stats
    • 1 reply
    • 3006 views
    • 0 kudos
    • 1 in conversation
    Announcements
