  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi bent2,
    Please check this similar post that is related to your question.
    Let me know if you have other questions.
    Kind regards,
    BrianL
    NETGEAR Community Team
    • bent2's avatar
      bent2
      Thanks. There is no soolution in that thread, but since it is 4 years old I was hoping that somebody had succeded in getting it to work since then.
      /Bent
      • BrianL2's avatar
        BrianL2
        Hi bent2,
        Let's wait for other community members to see if they have tried it on a newer or other ReadyNAS system.
        Kind regards,
        BrianL
  • This works for my RN202:
    apt-get update
    apt-get -y install apt-transport-https sudo nano git-core python python-software-properties software-properties-common
    sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
    echo "deb http://download.mono-project.com/repo/debian wheezy main" | sudo tee /etc/apt/sources.list.d/mono-xamarin.list
    sudo apt-get update
    sudo apt-get -y install mono-devel
    Hope it helps you. Now maybe somebody can help me. What's the easiest way to get python 2.7.10+ on r6?
    • JennC's avatar
      JennC
      Hello crw1985,
      Thanks for sharing!
      Your contribution is appreciated.
ProSupport for Business
