Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NASMonitor
- Mark as New
- Bookmark
- Subscribe
- Permalink
2008-09-11
11:37 AM
2008-09-11
11:37 AM
NASMonitor
NAS MONITOR
- Description: Nas Monitor is a "triple plugin" by default it will launch loadavg which display MeMory and ethernet interface usage
loadavg is a simple and lightweight method of monitoring load, memory usage and transfer throughput on a Linux server. Every method of monitoring has an impact on the system being monitored -- loadavg is designed to keep that impact as low as possible. It generates HTML & CSS charts, thereby shifting much of the work from the server to the client -- your web browser.
phpSysInfo is a PHP script that displays information about the host being accessed.
It will displays things like Uptime, CPU, Memory,
vpsinfo is a Linux server monitoring script, written in PHP, that provides web access to system status information. It gathers the output from several common Linux commands into one web page, providing a quick overview of the system's current state. - Requirements: RAIDiator 4.1.3+ and PHP ADD-ON
- Platform: NV/NV+ - DUO - 1100
- Current Version:3.2
NasMonitor 3.2
NasMonitor 3.1 (03/29/11)
NasMonitor 2.9 (02/20/09)- loadavg updated to 1.5
- correct smart info
- correct a bug which prevent add-on to stay enabled after reboot
- correct a bug regarding whois and uniq (thanks to klayson)
- NAsMonitor can be disabled from frontview
- New NasMonitor version (Whois supported ...)
- Support of Disk spindown added
- Button for each software added in the ui
- PHP removed from addons to reduce size need to install PHP add-on if the addon was never installed
- Crontable corrected
- Installation Notes: if you didn't have php installed before install PHP ADD-ON
You can access the 2 other plugins : http://nas@ip/nasmon/nasinfo.php and http://nas@ip/nasmon/phpsysinfo/ - Screenshots:
- Old Versions: removed.
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2008-09-20
06:34 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-01-20
10:07 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-02-20
03:01 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-03-29
09:01 AM
