Reply
Virtuoso
PHPBB V1.5 updated 09/10/08
YOU MUST USE RAIDIATOR 4.1.3 or Greater !!!
IF YOU DON'T HAVE PHP ALREADY INSTALLED PLEASE REBOOT THE NAS AFTER INSTALLING THE ADD-ON!!!
PHPBB V1.6: Download Here
Change since 1.5:
add a missing directory which can preent php from runing correctly (thanks jeremy for your help)
Change since 1.3:
add nl language + some missing image for en-us and fr
check if myssql is running and launch it if not
add an option to do a full backup (only files not the db (will publish phpmyadmin shortly)) or restore in backup share (it's a little bit long 2GB for an empty forum)
Change since 1.2:
correctly remove the database if addons uninstall / correct a rare bug where the addons page is ntot changed on step 2
Change since 1.1 : add dutch_sie language (dutch netherland not available)
Change since 1.0 : correct a bug in apache config
It's based on PHPBB 3.0.2
fr, en-gb, eb-us, en, br, nl language files for the forum are included Smiley Happy
after installation of the addon you will have 3 buttons use it in order
1) click configure to configure the forum and populate the database
database name is : phpbb
database user is : root
no password used
2) after configuring click on the 2d button which will remove the installation directory and let you use the forum
so know you can do a refresh in frontview addons list the PHPBB addon must appear with 2 buttons : launch phphbb and full backup Smiley Happy
enjoy it
If you like my add-ons - Si vous aimez mes add-ons :
EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
Where I'm teaching
4B Perros
Virtuoso
Re: PHPBB V1.5 updated 09/08/08
updated on 09/08/08
Where I'm teaching
4B Perros
Discussion Stats
  • 1 reply
  • 2224 views
  • 0 kudos
  • 1 in conversation
Top Contributors
