Reply
Virtuoso
PHPMyAdmin
PHPMyAdmin
  • Description: Administrate your Mysql database from a browser.
    phpMyAdmin is a free software tool written in PHP intended to handle the administration of MySQL over the World Wide Web. phpMyAdmin supports a wide range of operations with MySQL. The most frequently used operations are supported by the user interface (managing databases, tables, fields, relations, indexes, users, permissions, etc), while you still have the ability to directly execute any SQL statement.
  • Requirements: RAIDiator 4.2.1+ and PHP Addon for the PRO
  • Platform: PRO/NVX
  • Current Version: 2.5
    PRO PHPMy Admin (12/15/2010)
    PRO PHPMy Admin (02/11/2010)
    • solve a bug when add-on is disable (notice it takes time to re-enable it)
    • no more needs to reboot after installing this version
    • updated to the last multinlanguage version : 3.3.8.1
    • PHPMyadmin can now be disabled
      User is admin with your admin password
    • Installation Notes: you need to install PHP addon if not already done
    • Screenshots:
If you like my add-ons - Si vous aimez mes add-ons :
EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
Where I'm teaching
4B Perros
Virtuoso
Re: [PRO] PHPMyAdmin
updated
Where I'm teaching
4B Perros
Virtuoso
Re: PHPMyAdmin
updated
Where I'm teaching
4B Perros
Re: PHPMyAdmin
Is there a vesion of this for SPARC on a ReadyNAS Duo?
Regards
Chris
Guru
Re: PHPMyAdmin
Regards
Chris
There is, but the links seem to be incorrectly edited here: http://kb.netgear.com/app/answers/detail/a_id/24557 (and a lot of the add-ons listed in the kb don't appear to have been properly migrated to the new forum).
https://community.netgear.com/t5/Community-Add-ons/PhpMyAdmin-3-4-5/m-p/761737#U761737
Re: PHPMyAdmin
Thank you - wanted to make sure I got the correct one Smiley Happy
Chris
Discussion Stats
  • 5 replies
  • 2954 views
  • 1 kudo
  • 3 in conversation
Top Contributors
User Kudos Count
1
