× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
PHPShell
super_poussin
Virtuoso
PHPShell
PHPShell
  • Description: Let you access shell using PHP. (Please use it carefully)
  • Requirements: RAIDiator 4.2.1+ and PHP Addon for the PRO
  • Platform: PRO /NVX
  • Current Version: 1.2
    PRO PHPShell
    • correct a bug where phpshell did not stay enabled after reboot
    • PHPShell can now be diabled
      FOr the pop-up windows : User is admin with your admin password
      Defaukt phpshell user is poussin with password ReadyNAS (you need to change it)
    • Installation Notes: you need to install PHP addon if not already done
      if you do not have phpinstalled before and the interface did not launch correctly or if you have a message saying
      after installing follow this steps :
      browse this url to generate an encrypted password http://nasip/phpshell/pwhash.php
      edit the config.php in the webroot/phpshell/ share
      replace the line with the user poussin with the line previously generated
      log to phpshel and do a chmod 644 /c/webroot/phpshell/config.php
    • Screenshots:
    • Old Versions:
      Removed
      • Credits and Sources:
        [url=http://phpshell.sf.net/] PHPShell Web Site|/url]
Message 1 of 2
super_poussin
Virtuoso
Re: [PRO] PHPShell
updated
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3273 views
  • 0 kudos
  • 1 in conversation
Announcements
