Reply
Virtuoso
PHPShell
PHPShell
  • Description: Let you access root shell using PHP. (Please use it carefully)
  • Requirements: RAIDiator 4.1.3+ and PHP Addon
  • Platform: NV/DUO
  • Current Version: 1.2
    PHPShell
  • correct a bug where phpshell did not stay enabled after reboot
  • For the pop-up windows : User is admin with your admin password
  • Default phpshell user is poussin with password ReadyNAS (you need to change it)
  • Installation Notes: you need to install PHP addon if not already done
    if you do not have phpinstalled before and the interface did not launch correctly or if you have a message saying
    after installing follow this steps :
    browse this url to generate an encrypted password http://nasip/phpshell/pwhash.php
    edit the config.php in the webroot/phpshell/ share
    replace the line with the user poussin with the line previously generated
    log to phpshel and do a chmod 644 /c/webroot/phpshell/config.php
  • Screenshots:
  • Old Versions:
    1st Release
If you like my add-ons - Si vous aimez mes add-ons :
EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
Where I'm teaching
4B Perros
Virtuoso
Re: PHPShell
updated
Where I'm teaching
4B Perros
Discussion Stats
  • 1 reply
  • 1788 views
  • 0 kudos
  • 1 in conversation
Top Contributors
User Kudos Count
1
